allerlei audio + inbouw compact e36
Posted: 04 Oct 2009 22:05
Beste mensen,
Ik heb nog allemaal audio liggen:
- 2x 2 kanaals versterkers €25,- p/s
- 1x hertz ep-4 versterker (net nieuw €200,-) voor €150,-
- 1x kicker 10" sub €100,- (evt met kist)
- 1x audio system 12" sub €120,-
- 1x ground zero 4 kanaals versterker €120,-
- 1x inbouw bmw compact (zit nu ground zero versterker en audio system sub in)
Meer dingen afnemen is meer korting :p
Groeten,
Toos
info:
Kicker sub:
# 10" Single 4 Ohms Comp Series Subwoofer
# Power Handling:
* Peak: 300 watts
* RMS: 150 watts
# Impedance: Single 4 ohms
# Vacuum Formed Polymineral Cone with ISD (Inverted Structural Dome)
# Optimized Polyfoam Ribbed Surround Radius
# Double Stitched Surround
# Rear Cone Brace
# Spring-Loaded Nickel Plated Terminals
# High-Temp Polyimide Film Voice Coil Former
# 45oz. Magnet Structure
# Two-Piece Vented Hyper-Extended Blackened Pole Piece and Backplate
# Marine-ready
hertz:
SPECIFICATIES
Stroomverbruik: 28A max
THD: 0.08%
Demping factor (100 Hz @ 4Ω): 130
S/N Ratio (A weighted @ 1 V): 98dB
Bandbreedte: 7 Hz ÷ 60 kHz (-3dB)
Vermogen (4 Ohm): 4x 60W rms
Vermogen (2 Ohm): 4x 90W rms
Vermogen (4 Ohm gebrugd): 2x 190W rms
Vermogens zijn volgens CEA-2006
ground zero:
Product Features:
4 x 75 WRMS @ 4 Ohm (14,4 V, 1% THD)
4 x 110 WRMS @ 2 Ohm (14,4 V, 1% THD)
4 x 125 WRMS @ 2 Ohm (14,4 V, 10% THD)
2 X 220 WRMS @ 4 Ohm (14.4V, 1% THD)
500 W Maximum Output Power
2 Ohm stable
Bridgeable
Mosfet power supply
Adjustable Low Pass 50 - 250 Hz
Adjustable High Pass 50 - 250 Hz
Bass Boost
Foto's:
Groeten,
Toos
info:
Kicker sub:
# Power Handling:
* Peak: 300 watts
* RMS: 150 watts
# Rear Cone Brace
# Marine-ready
hertz:
SPECIFICATIES
THD: 0.08%
ground zero:
Product Features:
2 Ohm stable
Bridgeable
Mosfet power supply
Bass Boost
Foto's:
